So today I cut a piece of steel out on the HAAS lathe at work. The piece is 1.85" long and threaded on both ends. The threads take up around 0.75" of the part if I remember correctly. One side is .25" of #10-32 threads and the other side is around .5" of 5/16-24 threads. The rest of the shaft is .3" in diameter and a slight portion angles up to .375" right before the 5/16-24 threads. I am not 100% sure what kind of steel it is, I think it's 4140, but not certain, just pulled it out of the scrap pile.. I need to put a slight bend in this piece. How would be the best way to go about this? Heat? Would really appreciate any help with this. Not sure if I asked in the right place, but it is gun related if that helps Thank you very much!
Ben
Ben
