Not really a gunsmithing project but thought I would post it here because I suspect some of you deal with thin wall titanium in suppressor manufacture, etc.
I have a customer who has asked if I can "cut" some titanium for him. When I asked him to explain, I realized what he really needs is a tube parted into several pieces. The tube is grade 5 with wall thickness of about 0.010 (don't have measuring tools handy.)
1) I have a Seco insert parting tool. I have hundreds of inserts I bought at a tool sale. They are new but not in packaged and I can't figure out the types from the few markings they have. I'm gonna guess none are designed for titanium but I'm going to see if they will cut it. Even if I only get 1 cut per insert, I'm better off than buying new (I have about $0.03 invested per insert). Any reason to think they wont cut it?
2) when I work with thin walled Aluminum or steel, I turn a wooden rod to slip fit inside to keep from distorting the tube from the force of the chuck jaws. I'm afraid to use wood with titanium for fear the heat generated will spark the wood. Would it be ok to use steel, aluminum, or bronze or would they cause some type of reaction?
3) I have flood coolant reservoir and pump but don't currently have it hooked up. Think I could get away squirting coolant by squeeze bottle since it is so thin walled?
Any other advice about things I may encounter but haven't thought of?
By the way, lathe is 13" 5hp. I think I'll have enough power and rigidity.
