Reckless Ted
- Feb 10, 2018
I'm currently building a detachable-magazine C96 broomhandle Mauser pistol using an old Federal Ordnance frame, and I'm not sure if I need to be thinking about heat treating it.
A little background: The frame was sold as new old stock, presumably made sometime in the '70s or '80s. Based on the quality of the machining and amount of hand fitting I've had to do, I suspect that the frame is a factory second. Because of this, I suspect that if heat treating was part of Federal Ordnance's manufacturing process, this frame probably didn't get that far as the steel has been relatively easy to work (certainly much easier than some of the components in my donor C96.
I have two main areas of concern. First are the rails for the barrel extension, which need to be durable. Second is the lock frame stop recess, which holds the barrel and all the internals in the gun under recoil. I am concerned about this area because it appears as though the grip portion of the frame was made separately and welded on, and there was what looked to be a deposit left in the recess from the welding process.
Is heat treatment something I should be concerned about? If so, I would consider having it done professionally unless the costs were prohibitive.
Thanks for the help.
