I am attempting to make a copy of the DeLisle Carbine, a SMLE converted to .45ACP and suppressed. The donor rifle is an Ishapore 7.62 NATO that supposedly had a bad barrel and was difficult to open after shooting. At least that is what I was told by the seller who is a friend and somewhat knowledgeable. In any case, the barrel is off and I made an arbor (.583" d) to mount the receiver in the lathe as part of the receiver needs to be bored out as the .45 barrel is set back into the receiver and the bolt shortened. I will be boring out at least 2" of the receiver (starting after the barrel threads end) and want to support the forward end of the receiver with the center rest. I also want to be sure that the receiver is running true and will adjust the center rest to make that happen. My attempts at using an indicator on the receiver threads is not so good. The ball end on the indicator rides on the crest of the thread then of course drops off into the trough as the receiver turns. The measurement shows only one point when the receiver makes a revolution and comes to the crest of the thread again so it's not telling me what I need to know. Any clever ideas on how I can make this measurement short of turning and threading something to screw into the receiver threads for the barrel?
