I am currenty working on some screw in chokes for a turkey shoot gun. I am having problems getting threads 32tpi to form uniform an symetrical, i am using a hand ground 60 degree cobolt cutter an spindel is running at 85 rpm. The lathe is a 2010 jet gh1440, compound angle is set at 29 degree. would a indexable laydown cutter make the difference? threads are way too bad to use in a gun..
Speed it up(a bunch) and use some sort of lube if your not already. Near as i can nompute, your only running 13 or 14 sfm. Cobalt is only a bit better than plain ole HSS, which would like no more than 100 SFM. Have you ground a positive top angle on your tool? Sounds like you have it flat or negative, and the material is tearing rather than cutting. The lube would probably help most if your running dry. Try hi sulphur cutting oil if you have it, Mic-O-Cut would be better, but if you have that, you'd most likely already be using it.
I know it's more difficult to catch that lead at a faster rpm, but too slow and the material wants to build up at the cutting edge, causing a tearing action. The positive angle will reduce the heat somewhat, relieving some of your ailment. The lube will help some more.
What kind of DOC are you trying?
A carbide cutting tool will only exacerbate the speed issues you having. Indexable are all carbide as far as I've seen. You'll need at least 300 spm in most cases with carbide.
SFM =(dia x pi)divided by 12) x rpm. Try to keep HSS below 100SFM, carbide above 300SFM is a general rule off thumb. There is a max SFM that applies to carbide, but it depends on the material and hardness.
Also, a tiny radius on the tool tip will help it last longer. Probably easiest to hone that with a handheld diamond hone.
All this is subject to final destination charges and dealer prep. Your mileage may vary. Always be aware of current driving conditions and always use a designated driver.
