Quick Change Tool Holder for Jet Lathe
Results 1 to 16 of 16
    Aug 2007
    Kingsport, TN
    16
    Default Quick Change Tool Holder for Jet Lathe
    I own the Jet 14x40 Lathe and would like to go to a quick change tool holder. What brand and model quick change tool holder would you recommend for this lathe. I was thinking about the Grizzly or Aloris but not really sure if the Grizzly is worth the cost.
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    Aloris is the best but very pricey. I would go with a Phase II from Enco. I have a 100 phase II on my 14" lathe, that is the same size as an Aloris axa. It works fine but I used that size so I could share tooling with my smaller lathe. It would be better to go with a BXA in Aloris or a 200 in Phase II. Gary P. Hansen
    Aug 2007
    Kingsport, TN
    16
    Thanks . One more question . How hard are they to fit to your lathe ?
    Jan 2004
    Idaho
    76
    The only requirement to "fit" them to your lathe is to make a plate that fits the T-slot in the compound. It will be self evident when you have the toolpost in hand.
    I've suggested to a number of friends that they purchase the Aloris wedge type toolpost and then buy import adapters. That has worked well for them. I prefer the wedge style over the piston type.
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    If you order directly from Aloris they will machine the nut to fit your compound if you provide a drawing. Aloris tool post and a few too holders will set you back several hundred dollars. Phase II 200 from Enco is $119.95 for a piston type or $189.95 for a wedge. Most people like the wedge best but I like the piston type. If machining the nut is a problem for you, I will do it for you if you provide a drawing of your compound's T slot and pay the shipping both ways. Gary P. hansen
    Jan 2006
    437
    35
    I have a Dorian BXA on my Jet 13x36. I have never used an Aloris, but the Dorian is alledged to be more wear resistant over the long haul. All I can say is that my Dorian has performed perfectly for 15 years with zero maintenance.
    I use Phase II tool holders exclusively because they are much cheaper then American made holders and work just as well once you replace the cheesy set screws with some quality American made screws.
    RWO
    Jul 2006
    FL
    342
    Check with http://www.shars.com/ They carry the same import as Enco/Phase 2 and they are often less money. Website is crappy but they send out catalogs quickly. Go with the wedge type over the piston type.
    http://www.shars.com/product_categor...g__Toolholders
    Dec 2002
    Monterey Bay, California
    10,260
    28
    195
    CDCO has holders for $9 and up.
    The build quality is good. Certainly equal to Phase II.
    Aug 2007
    Kingsport, TN
    16
    I don't have a mill is the reason i was asking about fitting to my lathe. Thank for the info. I will check out the brands you have recommended.
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    If you have a four jaw chuck, you can use your lathe to cut it down to fir the T slot. That is how I do it. Gary P. Hansen
  11. #11
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    Go Back Practical Machinist - The Manufacturing Forum > Specific Machine Forums > South Bend Lathes
    Reload this Page Phase II AXA
    Sorry, I was trying to make this an active link. Guess I do not know how. Anyone want to explain it to me? Gary P. Hansen
  12. #12
    Nov 2007
    49
    just did the same myself
    Tool Posts..... Piston or Wedge?
    see the 2nd to last post.
    from my research, sounds like you'd need the 200 series.
    imo, no, ive never used an "expensive" one, but it was well worth what i paid for it. i dont change tools that often at all, and never to a precision that .001" repeatability on the height would ever matter to me.
    when i did the search, ive seen alot o people wondering how the cheap ones work,but no one would admit to getting one, so i decided to be a guinea pig and try one.
    ive only used it once today, but no complaints so far.
  13. #13
    Feb 2008
    Colorado USA
    110
    Smile Tool post
    I have one of this type works fine.
    http://www.harborfreight.com/cpi/cta...emnumber=34816
  14. #14
    Feb 2001
    Arizona
    2,041
    249
    When you are looking at the page you want to link to, cut (as in cut and paste) the URL from the browser's address box. Return to the post you are making and paste the URL into your text. Then place a {url= in front, a } at the right, the text you want shown for the link followed by {/url}, using brackets [ and ] instead of the braces { and }. If you want the absolute URL to appear for the in text link, surround it with {url} and {/url}, but that is not a good idea if the URL is so long as to exceed the normal width of the posting window. If it is really long, use a text surrogate.
    Example (using braces instead of brackets):
    {url=http://www.lassengunsmithing.com/html/specproj.htm}Cannon class Tool List{/url}
    This will show as
    Cannon class Tool List (the blue indicating a link)
  15. #15
    Aug 2007
    Kingsport, TN
    16
    I was wondering if you could use the same T that the 4 way tool holder is mounted on. The T on my lathe is very tight and I'm hesitant about hammering on my compound to get it out.
  16. #16
    Feb 2008
    Colorado USA
    110
    Smile Tool post
    You maybe able to use the same T if the tool post uses the same size and threads as the previous tool holder, not very likely though. If you need to hammer your current T from the compound this T is not properly fitted to your compound. Try to get some penetrating oil in there to loosen the T from the compound. Muley
