remington 700 bolt threading fixture - Page 2
Results 21 to 40 of 57
  1. #21
    Feb 2008
    McLeansboro, IL
    382
    22
    Talking
    I believe he is probably cutting a 5/16" stub and if you break it aff after it has been tightened against the shoulder, you might need to full length resize your brass or reduce your load.
  2. Likes snocat_trf liked this post
  3. #22
    Nov 2006
    Greenwood, Ca
    893
    39
    264
    you are correct, it is 5/16-24. i am also leaving approximately 1/4" of unthreaded shank. i see lots of people threading right to the shoulder and in my opinion, that is inviting failure. creating a stress riser right at the shoulder at the already weakest spot isn't the best idea in my mind. once the bolt knob is epoxied on, i feel my method is plenty strong.
    the thought has crossed my mind to eliminate the threads all together. i'd just machine a smooth shank and have my knobs slip fit. i would then use a retaining compound such as loctite 680.
  4. #23
    Jun 2006
    SWEDEN
    452
    390
    93
    I get your point regarding time and efficiency :-)
    Gluing is a good Idea for the right circumstances. But think twice with special regard to the materials and temperature.
    Good would be to make a very coarse surface finish and use a glue that doesnīt get brittle in cold, still with warning on plastic and aluminium handles. Also need to consider strong solvents.
    If you can hold tols you might consider shrink it together, then thereīs nothing getting deteriorated.
    I think itīs a little over-kill to threadmill that. Would it be faster for you to thread with a die in a dieholder since you still have to change tooling? (Donīt tell me now you got a big automatic tool magazine and itīs just a push on button.....thatīs cheating ;-) )
  5. #24
    Nov 2006
    Greenwood, Ca
    893
    39
    264
    Quote Originally Posted by Lumberjack View Post
    it's just a personal thing but i hate thread dies. if i was doing this to make money, i'd go to a insert style, full profile thread mill. it would save about 2+ minutes off of the job. i just can't justify the cost of the tooling as a hobbyist doing this for friends. shrink fit is not a bad idea and it has certainly crossed my mind. it's very rare that i say this but i don't think it warrants the effort. it's just a bolt knob.
    and no, i don't have an automatic tool changer. my tool changes are done manually with a manual drawbar. the tool holders are repeatable and the offsets are stored in the controller though.
  6. #25
    Jan 2005
    Salem, Ohio
    4,104
    47
    88
    Cool
    I don't want to hijack your post and nice work but my son wanted his Rem 700 bolt threaded and i don't have a mill just a small lathe so heres what i came up with. I made a block to hold the bolt on the compound and turned off the knob with a boring bar mounted to the spindle. I can angle the bolt body if wanted for a swept back knob. Just my thoughts...Bob
    Attached Thumbnails Attached Thumbnails bolt-jig.jpg   bolt-jig-2.jpg   bolt-jig-3.jpg
    Bob Wright Metal Master Fab
    Salem, Ohio Birthplace of the Silver and Deming Drill, all others are copies.
  7. Likes aninchlow liked this post
  8. #26
    Aug 2007
    Arizona
    How about the original PTG or the newer phase II Remington 700 Bolt Handle Threading Fixture?
  9. #27
    Oct 2009
    Parrish, Florida, USA
    450
    57
    Question presented.... Why must it be threaded on? To unscrew it to look at the threads? Best to weld it on. The removable idea is for those who like to see it screw on and off. Just sayin'. If you are a real tactical shooter, ie taking out perps and bad guys as needed, the larger knob is meant for quick follow ups (cycling the action faster) if a tacticool guy wanting to see threading.....get real
  10. #28
    Oct 2009
    450
    57
    We weld ours on if you didn't get our drift before. Chucker will be proud
  11. #29
    Nov 2006
    Greenwood, Ca
    893
    39
    264
    Threading gives options to change knobs if desired.
  12. #30
    May 2013
    North Carolina USA
    69
    12
    8
    Well I have to say that is slick way of doing it, I have a mill but think the next time I will use your method, nice job !!
    Quote Originally Posted by aametalmaster View Post
  13. #31
    Jan 2005
    Salem, Ohio
    4,104
    47
    88
    Cool
    Quote Originally Posted by adc1963 View Post
    Thank You...Bob
  14. #32
    Feb 2011
    Edmonton, Alberta, Canada
    2,113
    10
    554
    If you had a couple hundred bux you could buy a used Atlas or Southbend milling attachment for that little machine off FleaWay to get a third axis, stand it on end and you would have a small mill. Or you could use it the way it is, on its side. I have seen guys do some pretty remarkable things with milling attachments in lathes. Be it a bit unorthodox, there is always a way to get things done with what you have.
  15. #33
    May 2013
    North Carolina USA
    69
    12
    8
    Hey Bob, I meant to ask, did you thread your sons handle or just make it press fit..??
  16. #34
    Jan 2005
    Salem, Ohio
    4,104
    47
    88
    It is threaded 5/16-24...Bob
  17. #35
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    +1
    That seems to be the size for all the aftermarket knobs.
    Has anyone tried the reinforcement method used by Short Action Customs? Here's what they say:
    Due to the Remington manufacturing process, cavities are often present inside the handle. The standard bolt knob conversion can greatly weaken the transition from handle to bolt knob. For Remington 700 bolts, we drill out the center of the shaft and the handle, tap the hole for 10/32, and insert a hardened steel screw re-enforced with Loc-tite 271 and then face off for a clean finish. This strengthens the joint from the handle to shaft that other conversions can fail under normal conditions; that is Short Action Customs, LLC innovation!
    Or cut half an inch off & drill & tap for a 5/16 - 24 stud which seems like a better way all around.
  18. #36
    Nov 2006
    Greenwood, Ca
    893
    39
    264
    Quote Originally Posted by precisionworks View Post
    +1
    i still think my method is as strong without inserting the stud. i counterbore the knob so it is a close fit on a short shank. once it is glued on, any force applied to the knob is being transferred to the shank and shoulder, not the threads. i have yet to see any porosity daylight in the shank i form.
    i cringe when i see threads cut all the way to the shoulder on one of these installs, especially when it becomes an interrupted cut. that is creating a terrible stress riser at the worst possible place.
  19. #37
    Apr 2005
    Benton, IL USA
    4,567
    7
    44
    Default remington 700 bolt threading fixture
    Beautiful install
  20. #38
    butchlambert Guest
    You know? Why don't you send your bolt to Dan Armstrong Welcome to Accu-TIG and have a new bolt handle tigged on? No soldered handle to fall off, better bolt timing, and no expense for a knob and labor.
  21. #39
    Feb 2011
    2,113
    10
    554
    +1
    I don't know if installing a small stud inside is really going to strengthen it much. All you are doing is removing metal to instal metal and the area occupied by the thread is lost for axial strength so I think you may just be weakening it. I think I would just silver solder on a new handle if I found a large void in the cintered steel handle (I never have found a void to date). Adding a pin seams like a bit of a cheap shortcut. I have found that the common cause of breakage is from the furnace weld breaking because of added force generated by the added length creating more leverage against the weld or using 1/4 inch threads. I try to keep the added length to a minimum.
  22. #40
    Nov 2006
    Greenwood, Ca
    893
    39
    264
    TIG welded handles can fall off too. seen it happen more than once.
    personally, i think the best option for a m700 is waiting until a new barrel is to be installed and have a true one-piece bolt ptg bolt fit at that time.
