Mike RzMachine
Cast Iron
- Feb 4, 2007
- Utah
i'm wondering what's involved in rebarreling a ruger gp100 in .357 mag. i haven't taken in apart, as i'm not sure i want to do it myself.
i'm wondering how the barrel is tightened and aligned.
does ruger cut the barrel threads with a certain clocking?
does the barrel have a fine enough thread that it can be torqued until the barrel is aligned by deforming some portion of the frame or barrel? (seems most likely)
is the barrel assembled to the frame with shims to get it to stop at the correct position?
what are all of the tolerances that need to be held when rebarreling and where can i find them? barrel to cylinder gap, barrel rotational alignment, torque, others?
it's not a high priority project, i'm interested in what's involved. are there any issues that aren't obvious?
Mike
Mike
