Dave W
- Jan 10, 2007
- central Arkansas
I've been making some sketches for a turnbolt receiver. I've pondered the conventional screw-in barrel vs. the Savage style barrel nut, the second-design Arisaka takedown attachment, etc. The main factors have been my skill level and the equipment I have available.
While looking at some of the slide-and-pin takedown designs, I began to wonder... has anyone encountered a rifle with an interference fit barrel?
Back in ancient times, some ball bearing manufacturers made bearings with threaded inner races, to positively locate them on shafts. These were largely superceded by various taper attachment methods. These, in turn, are being slowly replaced by the "SKF oil injection method." This is also used for assembling built-up crankshafts with roller bearings.
Basically, you make your parts with whatever interference fit you select. One part (depending on what's convenient) has an annular groove connected to a port, which is then connected to a high pressure source full of oil. This can be anything from a grease gun to a 6000PSI hydraulic pump depending on the situation.
The annular groove feeds oil to the joint, spreading the pieces apart so they can be slipped together and aligned easily. Then the pressure is bled off and the parts clamp together.
For disassembly, you just pressurize the joint again and pull the pieces apart; no chin-ups on the barrel wrench needed. (and no need to cut internal threads at the front of the receiver!)
