reedeprintice
Stainless
- Feb 22, 2008
- Paradise , California
I would dig seeing this done , Its interesting I have a broach and would not mind learning how this is done . Jess
Tooling costs would be the killer. Custom broach for every bore size and twist rate.
My (inexperienced) opinion would be that the tooling costs would only be worthwhile if one were making a LOT of same barrels.
Anyone ever have a broach made? What's the cost like compared to a button on a tube?
Cheers
Trev
You can always hammer forge. (if you have the big bucks)
BEHIND THE SCENES: DANIEL DEFENSE - YouTube
" being compressed into shape" You mean like work hardened ? How could that be so bad with copper sliding on carbon.Ummm you mean pull the broach through..
Broaching does not induce heavy stress in a barrel, like button rifling does.. In button rifling, the steel is being compressed into shape, not like cut (single groove) or broached (all or multiple grooves cut at same time) rifling..
So... post broach stress relief, would not be as important, as on a button rifled barrel....
The next step up in creating internal barrel stress, would be Autofrettage, Which actually uses interior barrel stress (applied by high pressure hydraulics or a button), to allow thinner lighter cannon tubes (but still durable) to be made...
God Bless Harry McGowan and buttons. I made a lit of money betting on single holes and .222
Re compressed into shape..
I am trying to keep things simple..
Simply bending a hacksaw blade back and forth, work hardens the steel until it snaps. Molecules are being compressed and released...
You saw the word autofrettage...
Similar stress is caused by running a button through a rifle bore, bore surface work hardens.. Bores that are button rifled, tend to have a longer accuracy life, than broached..
Yes hammer forging is done with work(barrel) moving over stationary button/mandrel.. A big $$$$ operation..
Stess can be good (as in autofrettage) or bad. Bad stress in a rifle barrel, would be uneven amounts of stress over its length, thus POI changing a barrel heats.
A problem with barrels (especially button rifled) is they are most often rifled as a blank. Then turned to needed profile, this changes the internal stress (and often bore dimensions) to a small degree.
There will never be a 100% perfect stress free, long lasting accuracy, tapered barrel. 99.8% is good enough..
But one source says that a barrel to be buttoned, is softer than it needs to be if it will be cut rifled.
Bill
Notice
