hoagiem
- Nov 12, 2011
- new mexico
I have drill fixtures for the P12 casting that is currently being sold by Sarco. The drill fixture is $105.00 shipped via priority flat rate small box. I used this one myself to verify hole locations and it works great. If you have any questions please let me know. This fixture is the prototype . The next ones will be square. The hole locations are placed at the proper distance from a finished surface of a mil spec frame. The fixture can be zeroed off the top surface of the side plates and then the frame top surface can be machined to correct dimension for drop in fit or left over sized for a lapped fit. The fixture comes with instructions and a list of required drill bits and recommended reamers. The fixture includes two 3/8" aluminum side plates, three bolts, three washers and three spacers.
