Securing a threaded on chuck for reverse rotation
Results 1 to 14 of 14
    Nov 2016
    12
    5
    Default Securing a threaded on chuck for reverse rotation
    Good evening,
    I do little gun smithing but I note this forum is more accommodating of Asian machine discussions than the general forum so I thought I would ask the following:
    I have a Grizzly 12X37 lathe (along with an SB Model A and Wells Index 747 mill, and access to a Lodge and Shipley 18X54.) Do the latter get me a pass, Don?
    I prefer to thread from the head stock out so I want to secure the chuck for reverse operations.
    There is room to drill and tap the back plate on the three and four jaw chucks I have to 3/8"-16.
    So my thought is a dog point or cup point set screw securing the chuck. (not on the spindle threads, obviously).
    I thought about using a brass or lead plug under the screws but abandoned that as there is only .500" depth to work with.
    Three at 120 degrees should to the job?
    I know the spindle is hardened. I know how to not over tighten a chuck on the spindle
    Typically I don't take heavy cuts when threading and grooving.
    So wattaya think?
    Tony
    Feb 2001
    Arizona
    2,041
    249
    Both of my lathes have threaded spindles (although the back plate seems to be frozen to the spindle on the older machine) and I have not had any problems with the spindle unscrewing while running in reverse. But neither machine has any way of braking the spindle so hard that the chuck will unscrew. Also, the old machine won't go very fast so the chuck does not acquire a great deal of angular momentum. If threading is your only need for reverse, I doubt you will be running so fast as to unscrew on starting, either.
    Nov 2016
    12
    5
    Good morning,
    Good points. I had thought of that particularly starting. The green machine has an eight inch four jaw that is pretty heavy. (for the size of the machine.) The machine is capable of thirteen hundred rpm but I seldom go beyond nine hundred. I swap chucks fairly often and don't secure them gorilla tight. It's making a 1"-2" long deep cut in the middle of a shaft that I'm thinking about. If the tool jams.......Obviously a follow rest or steady rest helps. There are times when I could get away without the extra work setting up the rest to eliminate noise and chatter. And.... Threading in reverse gives the option of increasing the speed without the fear of crashing to get a better finish and not having to cut a relief at the end of the thread.
    I think I'll drill and tap for a couple of set screws over brass slugs (that I'll have hunt down in the chip pan and on the floor every time I switch chucks) in the back plate. Peace of mind, I guess.
    A little off topic:
    In the 70s a machinist who had spent thirty plus years at CAT showed me how to thread from the head stock out. Same for running in reverse cutting wide deep grooves in nasty or hard materials. In addition, replacing a live center with a dead center when all else fails to control noise and chatter. I was in his shop on a day when he did it. Later, beer in hand, I remarked that I couldn't feel much if any play in the live center. His only comment was, "It doesn't take much". ENd of discussion.
    Thanks for responding.
    Tony
    Jun 2012
    Michigan
    8,288
    2465
    2757
    I don't thread out from the chuck.. but if I did I would keep RPM low...
    I have used a lot of threaded spindles and have not lost a chuck.
    Sep 2009
    Phoenix,AZ
    1,366
    2183
    303
    You CAN get set screws with a inserted soft tip !
    Oct 2005
    Pittsburgh, PA
    1,581
    101
    The better back plate /chuck designs usually used split collars to prevent unscrewing.
    Attached Thumbnails Attached Thumbnails emco-face-plate-1.jpg   emco-face-plate.jpg
    17,010
    7162
    5317
    Quote Originally Posted by Andy St View Post
    Some among us settled for a strategically placed slice of copper or aluminium foil, "company lathe" and no messing about with set screws allowed.
    Don't leave it in there after the job is done, though. Bubba is only criticized when his jackleg tricks to JFDI and git 'er DONE are caught-out a year later when the chuck ain't COMING off when one wants it to.
    Jan 2014
    South Jordan, Utah, USA
    352
    802
    124
    Please elaborate. I'm interested.
    17,010
    7162
    5317
    Quote Originally Posted by Yan Wo View Post
    Lessee... late 1950's. SB 10" & Logan. 2 and something 8 per if old memory serves.
    Copper foil was thin strip, VERY! Not wide atall, no ROOM for it otherwise, and it is wedged, chuck not actually allowed to go 100% onto the register shape at the rear.
    OTOH, it dasn't offer to come off easily, either.
    Downside was it took expertise to PLACE it just-so. Upside is it was easily portable, later, to Day Job where the machines were not mine.
    The "School solution" we worked out later was better - took no skill. We cut a narrow, large-bore "washer', of 26 ga. soft aluminium and put it on first, chuck second. Didn't even affect TIR all that much, and it was a school, so TIR didn't matter as much has "concept". And safety of school-age kids. Started 'em younger back when their Dad's were working for mills and such. Or RAN them. A classmate's Dad was CFO, Mesta Machine. His Uncle Louie was CEO. Rank and file or ULM, all still recognized metal working as a valuable skill, whether one worked at it or hired those who hired those who hired it done.
    That "washer" TOTALLY stopped the chronic pranksters that would push the "REV" button of a 3-Phase 3/4 HP instant-reversing motor at full-gallop to roll a chuck at the feet of their classmates.
    And the SB even more than the Logan would DO that, and with great reliability before we added the washer.
    Most ere sayin' it ain't a problem are not bored school kids trying to MAKE it happen, is all.
    Meanwhile - glad to have seen the back of threaded noses altogether, but that was as much luck as planning.
    May 2017
    FINLAND
    952
    230
    453
    Quote Originally Posted by GGaskill View Post
    My 11x24 Kerry has also threaded chuck. I thought that its not a problem until it once got loose on threading operation... NOT fun when 160mm chuck is spinning on lathe ways and jumps towards your toes!
    Thanks to fast reflexes my toes are still intact but the ways took couple of extra dents.
    I added split ring to clamp on the collar. Kind of hard to believe at first but I didn't need to split the collar, it's very close fitting so just tightening the ring around the chuck collar locks it in place.
  11. Likes thermite liked this post
  12. #11
    Oct 2005
    Pittsburgh, PA
    1,581
    101
    Quote Originally Posted by MattiJ View Post
    I agree with MattiJ on this. If the back plate is a good fit to the register just a split collar will do, no need to split the back plate / mount. One problem is that not all lathes with lets say 1 1/2" 8tpi have exactly the same size register. So a third party chuck might fit a South bend correctly but not a Rockwell.
  13. #12
    Nov 2016
    12
    5
    Quote Originally Posted by JohnEvans View Post
    Arrrgggg! Forgot about them. Thanks for the reminder.
    Tony
  14. #13
    Feb 2017
    Ohio
    67
    5
    Quote Originally Posted by tcom View Post
    Tony
    Or you can make them
  15. #14
    17,010
    7162
    5317
    Quote Originally Posted by Brodytonelotti View Post
    ... or thumbtacks.. or Bostich staples...or 4-penny box nails .. but WHY?
