Results 1 to 10 of 10
    Oct 2007
    Tooele County, UT
    6
    Default Shotgun chamber bushing?
    Hello all,
    I'm in possession of a Remington 11 semi auto 12 g shotgun that is having trouble extracting. Looking in the chamber, it has a number of pits. I've searched brownells, midway, and generally online, but I've not found a sleeve for a shotgun chamber. I've found one gunsmith online that installs a tight chamber in shotguns for $95 plus shipping. I'm wondering if anyone has done a chamber sleeve, or knows of a supply for such sleeves. I know I should probably just be looking for used barrels on ebay and gunbroker, but it just seems like sleeving the chamber on this barrel shouldn't be all that hard.
    dave
    Alpacca Fortyfive is offline Stainless
    Nov 2007
    Leinster, Ireland
    1,154
    Sleeving the full length of say a top quality antique pair of damascus barrels would not be unusual.
    Sleeving just the chamber of a modern production shotgun:
    1. would likely cost more than a fresh barrel
    2. if the solder or epoxy holding the short sleeve isn't perfect, it risks letting high pressure gas round the front of it into the bored out space for the insert. - more area to act on, thinner walls to retain it
    Someone posted a while back about the "low pressure" that shotgun loads operate at.
    A vehicle tyre popping at 40 psi will happily take your face off. Shotgun barrels are designed to take the operating pressure without building in excess weight.
    My 2 cents says buy a fresh barrel.
    edit:
    Check out your extractor for wear and try some different brands of cartridge too. 1970s made Mossbergs had difficulty extracting European made cartridges even when brand new, there was a difference in rim profile. Variations can occur.
    jimcc is offline Plastic
    Sep 2010
    mn.,usa
    21
    Default sleeving shotgun chamber
    how about a sleeve screwed in similar to a screw in choke ?
    Gazz is offline Hot Rolled
    Sep 2004
    NH
    771
    I might try some PC7 or JB Weld in the pits. There is also a Devcon product that is used for making stamping dies that is quite tough. Then use a flap wheel to make the chamber smooth.
    ulav8r is offline Cast Iron
    Feb 2003
    Russellville, AR 72802
    340
    While you are checking it out, inspect the breach block very carefully around the grooves that the locking bolt ride in. They are prone to cracking and can cause problems before they give out completely.
    Kestrel4k is offline Plastic
    Jun 2012
    Oregon
    Quote Originally Posted by Dave, tool duller View Post
    Sorry to bump an old thread, but I came across this forum while doing a search on this topic, so I joined to post another inquiry on this.
    I have exactly the same issue as the OP, it's a Remington pre-11 (mfg. in 1906) with the same issues as the above. I am interested in having my local gunsmith attempting to fabricate & install a chamber insert (retaining the 12 ga. chambering). I was wondering if anybody might have anything to add to this thread with regards to their experience on this. I know that it might make more sense to purchase a replacement used bbl, but I'm willing to go to the expense of trying to retain the current bbl - this shotgun has some family history to it.
    My LGS has inspected the bbl and he considers it to be structurally sound, but has so far been unsucessful at polishing the chamber enough to get even low-base shotgun shells to extract from the pitted chamber.
    kendog is online now Aluminum
    Apr 2008
    West Coast
    182
    Briley Mfg. does quite a bit of shotgun work of this type. If it can be done, they can do it.
    Jun 2012
    Oregon
    Hi kendog, thanks for the reply.
    I already checked the Briley website and it sounds like that is a relatively straightforward repair for them - for $275.
    I checked a few gunsmith websites and the going rate seems to be ~$150. It looks like the last time the OP was here was Oct 2010, so I'm probably out of luck to see what his solution was, if any.
    At any rate, my gunsmith called me this morning - with more chamber polishing the gun now ejects shells correctly. He was worried it would require too much material to be removed from the chamber but it looks like things may be OK now.
    Anyway, looks to be a good forum here. Thanks,
    SOFMatchstaff is offline Plastic
    Aug 2009
    Las Vegas
    32
    I have used a product called Belzona E super metal to fill pits in chambers in an old double, just to see if it was viable. worked OK , but had to blast the surface in the bead blaster to assure the adhesion, then recut the chamber with a long throat reamer and polish abit. still hanging on 2 years later. I dont shoot it too much, and get it hot, so I cant say how the repair will survive in the really long run.
    I know the stuff worked well on pump and air handler shafts that were galled heavily. Big difference in the expansion in a chamber tho...
    RDCutter is offline Aluminum
    Apr 2009
    N.E. Ohio USA
    198
    Most of the chamber wall pitting in today's shotguns, is due to the plastic hulls. Heat, chemical reaction, condensation.................... I had the same problem when I shot ATA registered trap. Every day, home or away, get out the chamber brush, and Shooter's Choice. Then do the same to the choke area, and the full bore. Then swab the bore with a light coat of Starrett M1.
    Regards,
    Bob
