Shotgun choke tap question
Results 1 to 6 of 6
    Missouri, USA
    21
    Default Shotgun choke tap question
    Greetings,
    I need to tap a 12GA barrel for a choke that has 32tpi threads. What size tap do I need. The ones I see on Brownells have 44tpi threads. Thanks in advance for your help.
    Patrick
    Oct 2009
    Parrish, Florida, USA
    450
    57
    Patrick,
    To be honest, a tap is not the best choice. Do you have a lathe or access to one? 32 TPI is a fine thread and hard to get both right and concentric with a tap. Just food for thought.
    Feb 2011
    Edmonton, Alberta, Canada
    2,113
    10
    554
    Piloted choke taps are all bastard size. If you want one not offered commercially you will have to make one or pay some one to make you one. Pacific Tool and Gauge might do it for you. Taps are pretty simple to make.
    Nov 2011
    WA, USA
    18
    Both Winchoke and Remchoke are 32 tpi, Brownells sells taps for both (very hard to find stuff in their online catalog for some reason). You can also rent them from some of the same places that rent reamers.
    Nov 2011
    Wyoming
    293
    55
    102
    Manson Reamers sells three families (last I looked) of choke tube taps and reamers. Might want to give Dave Manson a call and inquire about your issue.
    Missouri, USA
    21
    Thanks for the advice!
