Winterfalke
Stainless
- Mar 26, 2011
- Huron
I have a Hi Standard Sentinel with a broken trigger assembly. The original appears to be machined from an aluminum casting, and does not have a lot of critical features. It also has a badly designed stress point; the lever that raises the hammer in DA mode is connected through a pair of aluminum tabs only 1/8 x 3/16 thick. When the trigger guard was broken, all the stress of pulling the trigger gous through these points.
I would like to reproduce this part out of titanium or carbon steel, and bulk up the web around the trigger. I am confident I can reproduce all the geometry within working tolerances, but I am not a gunsmith. What certifications or permits do I need to do this legally? Is there a cheap or base-level gunsmithing class that I can take? My biggest concern is staying on the good side of the ATF, and preventing the shop I work in from having any liability. I am a fairly experienced machinist, and I have been shooting and studying gun design for decades. I also have engineered a number of parts for the military simulation and aircraft maintenance fields, so I do have some idea what I am doing. I am in the Orland area in Florida, if that helps.
