I am getting ready to start on my PPS43 pistol project. But I have gotten mixed info on the proper way to register it. The local Sheriff dept. where I go to register my handguns said the State Police need to stamp ID numbers on it. I informed them that the BATF only required that I stamp ; Gun name, the caliber, My name, City and State and a unique set of number to the gun. She then said if that is all the BATF wants then that would be OK with them.
Any one done this in Michigan before?
Jeff
Jeff,
I just did one about a couple months ago. If you have a CPL fill out the RI-060. You are the seller and the purchaser.
Manufacturer = your name
Serial Number = What ever you want it to be or " " (there is no requirement to have a S/N on a firearm you made! However, without one how do you prove it's yours?)
Caliber = If fixed caliber state it, else "VARIOUS" My AR pistol is listed as "VARIOUS"
Shots = Max REASONABLE capacity if removable mag.
Type = Pistol
Barrel length = length from Muzzle to breach when closed.
Model # = What ever you want it to be or "NA". Again there is NO requirement to have a Model # on a firearm you made!
Take it in drop it off. You don't have to engage them in conversation if you don't wish. However, I usually leave them with my phone # in-case (WHEN) they have questions. The one that always hangs them up is the Manufacturer. YOU are NOT in their list of codes and they have no clue what to do. The manufacturer code is "ZZZ" followed by your name. Then they have to phone the MSP.
I have NOT seen a "License to purchase a pistol" in so long I have don't know what may or my not be on one but you should be able to glean the needed info from above.
You only have a short time from when you finish the "FIREARM" (in your case the lower) until you HAVE to register (I don't recall the time off the top of my head, SO I would advise no more than 10 days). It does NOT need to be assembled nor do you even need to have all the parts. Once you have it to a point where the FCG can be installed it IS a firearm.
To be CRYSTAL clear. BATF has NO REQUIREMENT for marking a self-made firearm. ALL requirements for "Markings" pertain ONLY to manufacture for sale. HOWEVER, I think if you are going to make a firearm you should at least have enough pride in your work to put your name on it. PERSONALLY I put my name on EVERY firearm I make along with a S/N for identification (My birthday: DdMmYy-X where X is a running number). I rarely mark a "model" (pistols only and only sometimes) and have NEVER marked city OR state (so far).
IF you
EVER sell a self-made firearm (I advise against it) the markings you listed above
IS REQUIRED prior to sale.
