I'd be interested in seeing more about it, too. I've hardened and heat treated quite a few items since the late 70's, and do play a bit with the colors, sometimes. To get the full range, generally, the part is going to be at a pretty high tempering temperature. For instance these parts are essentially springs, to back up the cutting tool (plane iron) They are air-hard steel, tempered back to about 540F (not critical for the app, basically still around 59 -60Rc for airhard). For water hardening (1095) that would be a little lower, maybe 55Rc. If you go over about 575 - 600, the colors all disappear and the steel is just grey again. Around 475, +/- 20 degress or so, there is a range wher you get beautiful golds and coppers, the higher temps fading into purples. I often make cutting tools that are a pale luminescent(sp?) gold, just for the effect.
I am mostly interested in the condition, so these are done in the kitchen oven, and I leave a bit of oil on them. The oil helps provide a surface range of temps that give the mix of colors, instead of all one color.
For instance, you can see in these that the coloring was sort of an afterthought. To do it right, the metal prep needs to be flawless. coloring won't hide scratches or poor surface finsish (as you can see in the photos!
) I was playing with the idea of coloring since the parts had to be tempered anyway, but had expected to polish off the surface to bright after heat treat. I sort of like the effect though, and might polish them and retemper for a better color/finish combination. Or not. there's too much to do int life!
If you can work from the backside of the metal, for cosmetic purposes, you can run a flame around, and it will give the dispersion out from the center of the flame, in all the colors.
Again, lately the effect for items like this has some appeal, and I would be happy to see others experiences and information related to the control of the comsmetics aspects.
smt
