I have a Stevens 315 that was excessively hard to open with huge firing pin drag marks. I measured the firing pin protrusion at 0.100 and 0.154. I looked up a spec that said a 12ga should be .050-0.076 for protrusion. I shortened the firing pins so that they were right at the 0.076 number and centered. Inserting a pair of fired shells and pulling the triggers it is much much easier to open with no excessive firing pin drag.
After test firing I get light strikes and roughly a 50% ignition rate on the right barrel. It shot well (aside from needing to be Samson to open it) before I shortened the FP's. I was testing with AA's. The hinge is tight. I think I have plenty of protrusion, I don't know if the headspace is to large or how to measure it.
I'd like an opinion on either extending the firing pins to say 0.090 or I can shim the main springs to make it hit harder, or both. Seems like they hit plenty hard. I can see a faint mark on a shell that didn't fire correctly. Fired shells from the same barrel have good primer indent which leads me to think there is a headspacing issue and the shells are setting back after firing.
