I'm having a hard time spot annealing a U.S. 1903A3 reciever for drilling and tapping. I use the radiused rod, 3/8" od, tinned for better heat transfer, heated red hot and brought down on the spot to drill method. Left to cool, slowly, I drilled and tapped 2 of the 3 holes like this. But the forward most hole, next to the barrel, is staying hard. I've done Springfield and Enfield recievers before this way but this one has me flummexed. I tried using a half inch rod for more heat transfer and slower cooling but that didn't work. There's more metal under this hole, barrel shank, so heat transfer is different. Any thoughts or new ways to do this are appreciated.
