Ok I'm not the best at explaining but here goes. Here is the short before the long. For the last 2 years my compound took .045 on the dial at 29.5 degrees to finish to the proper thread depth for an 18tpi 1.062 barrel tenon. The last few barrels my dial has been reading 37. OK now, what I am having happen is about ever .015 or so my threading tool is taking a bigger bite than I am dialing into the compound. I'll feed .002 or .003 on the dial at a time and usually that is what the threading tool will remove. However once or twice through out the tenon the tool gets hungry and takes a bigger bite than I am dialing into the compound. I have looked all the obvious things over and I just can't see what's moving. My lathe is a new import of decent quality with hardly and wear. Actually no wear. I hope this makes since to someone. I need some advise. Thanks fellas. Lee
