Thru the barrel coolant
gmich
Mar 28, 2015
Does anybody have any clever ideas on how to adapt a flood coolant system to one that can pump thru the barrel while I chamber?
Something akin to a rubber expanding test plug, with a rotary swivel hanging off it ?
The Deublin fittings work well and require very few other parts. I just use a short length of vinyl tubing and some hose clamps. Coolant is supplied by a modified (smaller bypass spring to reduce pressure) carbonator pump.
Vg1dpqcH_4BkyRJg8_SyX550U5dZ1gqYEsBavpcYoDzbmChSM7  q-sIoCwVtjB8FcMiQe742mDsOqlIvBtLM0Er1MCWDZA5Rc87dWo2  zCjfoSqB2EWkIVb7sfUp6NPWcHCnlY2jO6YaFG0GGaWkvbigcc  6xDyNGwFsCpAXC-0AsNJcfCMapRvm5cPJMY7de9BshlTyyXTq5PQodKowxI1l1guY  M8jt-Z2NJQpL3gPLYk_7gNcbF3ssAtPUtmm2hrjmdWfvpm4CYL2QKHi  BQ0RL590L8qA0LSf23yP0qql0GerydWbVuKzgm9_IvveqakZB1  AZrP3qBkb8wVjS-utg_gVX0El56Zn7LO2amA6QbaOEmi4YbANyGaAeS4RvlJxlyaO  R7pGJBYRN7TUsgTvPTvkWVO2TFl3_8FHVvCAiAJUSM9F99_8__  e6oawKWzLWLiVEQ3gT1wL074p4wUfOJJdEQihWTWh_0uGP3gYv  lW9Dw0reR-pXZ1f4PJpl_3MFeW7LnX9IXiyvIn-F7E1SDZUhhjgfHxPDzf9sMRKrzoUBObvQOIvdptfEMsKGdqGy_  NLc8CQUMrU2y9JLqr-CaFvnBezu3ImnhLQ1ynVll_kkPiuyLjDg4wz5WRTDOFFFXuBIN  XBLBW_5OzTalTZI4ZWozvadza8OV_w=w1024
That fellow who used to post here, but has moved on to accuratereloading advocated using a simple pneumatic quick coupling for a rotary joint.
They may not last forever, but you can buy them at the local hardware / farm / big box store, and they're cheap.
Better yet, the other parts look to work but are for far more intense application and the cost to try one out looks fairly steep.
I will google this description and see what floats to the surface. Thanks
Go to Deublin’s website, find a rotary union that meets your requirements, then search that part number on eBay. The one I’m using now is good for 12,000 RPM and I think I paid a few hundred for it. That’s not nescesarry for most people. You should be able to find something around $50.
This subject has been discussed in the past both here and on gun forums. Acurate Reloading, Accurate Shooter, Benchrest Central to name a few. Google and the search function on each forum are your friends.
There is an ongoing discussion of muzzle pumped systems now on Accurate Shooter.
You can buy components or make your own. I made my system some 30 years ago. 10 gallon sump with integral pump behind the lathe.
Does anybody see the good reason why this would not work?
SPEEDAIRE Steel Swivel Connector with (M)NPT Hose Connection - 30E593|30E593 - Grainger
SPEEDAIRE Swivel Connector,1'/'4 - 3E593'|'3E593 - Grainger
I prefer the quick coupler idea. First, the quick coupler is easy to install and disconnect. Second, it maintains straight alignment. Put an elbow on it, and it's straight down to your reservoir and pump. The swivel, isn't straight, and doesn't look like it turns 90 degrees. Actually, if it is straight down to your reservoir, it doesn't even matter if it leaks a little.
The rest is top secret.
If your a cheap A$$ like I am, maybe try this....
I setup my barrel in the lathe and center the muzzle super quick only to .001" then I drill and tap it 1/8"NPT with a short bottoming tap. Take the barrel out and setup back in the head stock with the breech in ready for cutting the tenon. Dial in the barrel how ever you do it. I use a cheap swivel air fitting and a 1/4"NPT to 1/8"NPT brass fitting and screw it right into the barrel never leaks and spins easy.
I thought I understood until I thought about tapping the muzzle end to 1/8" (.125"). Even a .177 is too large for this. So clearly I don't understand what your tapping. I did find the air swivel adapters and wondered if they would not be perfect for this but I assumed I would have to step sizes to the coolant hose and the barrel muzzle O.D.
Its 1/8" NPT which is closer to 5/16" and yes I drill with a Q drill bit .332" so this works for anything under 8mm if you do a 338 rifle barrel just drill and tap for 1/4" NPT threads.
