sabre85rdj
- Jan 3, 2010
- Moweaqua, IL
I've got an old Marlin Ballard falliing block action I'm wanting to rebarrel. I'm planning to fit a GM barrel with an OAL of 24 inches and I'm machining it on a LeBlond 19 inch gear head lathe. I have a small problem. According to everything I've read, I should support the barrel as close to the breech as I can in my 4 jaw using something like 1/4 in. copper wire and the other end should be supported with a spider at the end of my spindle to avoid bending or stresing the barrel and then center both ends to the bore to within a tenth or so. My barrel blank is 27 inches long and the spindle is 37 inches long so I can't machine it in the way I'd like. I can turn it between centers but will I get the same precision? I don't see anyway to dial in the muzzle end of the barrel besides relying on the center to provide the alignment. I'll have to use a drive dog on the muzzle end of the barrel and use a steady rest on the breech end of the barrel to steady the barrel while I thread the barrel. This won't be as ridged as chucking up the barrel, but I can't see any other way to do it. I'd welcome any comments or suggestions.
