I believe I have an 870 laying around somewhere. I shoot trap with a 28 gauge and sometimes upgrade to an old S&W 20 gauge which I just paid more to have repaired and get extra parts than I paid for the weapon.
Ok, "Draino" and metal;
Yes, removes aluminum from about anything... endmills, die-cast tools, even carbid engraving bits. The fumes however are the problem. Anything that comes in contact with them will oxidize and rust, even if the object soaking doesn't. I just learned this trick and tried it with some "soldered-up" cores and it worked awesome. But anything in contact with the vapors ended up in bad shape. I will continue to use hydro for those loaded cutting tools, and occasionally a badly "soldered" and "heat-checked" cavity, but not around any other sensitive objects. I spoke with an engineer whom I respect more than any other engineer that I've worked with in 15 years. (He was a tool-maker.) Pure hydrochloric acid works wonders, not just on what your cleaning, but anything that's left around the vapors. Of course you can't seal the container, we've all seen Mr. Wizard or some similar show that shows us the ole' two-liter bomb.
Unless it's a major issue that they don't want me to spend the labor hours on, I will reserve this method for special cases, or my own stash of cutting tools. In the mean-time I will continue to hog off aluminum with diamond bits, files, argofiles, etc... then follow with paper and or wire wheels. It's a pain in the ass, but better than having to polish everthing else in sight. (Fume)
As far as diamond files, they work great especially for non-ferrous metals. Of course they work great on hardened steel, but there is a chemical reaction which wears them down fast. If you buy a $200 dollar set of 7 needle files, you may think twice about using them to add a radius to a piece of D-2 or H-13. You will find some $30 dollar sets from our great friend, ha ha, China that you won't feel too bad about wearing out.
My suggestion for saving your "loaded" cutting tools with hydro, is to go ahead and soak it, just away from anything important. I.E. Grinding Chucks, precision tools, collet's, scales, etc...
