Results 1 to 5 of 5
    cmussel is offline Plastic
    Dec 2010
    Oxford, CT, USA
    Lightbulb Machine Lighting
    Sorry...this is my first post here and I don't know if this is the appropriate forum but I wanted to share.
    I've restored a number of antoque woodworking machines and I just acquired a vintage Sheldon lathe. In almost all cases I upgrade as well as restore, adding lighting to the machine. I'ts been hard finding gooseneck lighting that fits well on any machine but I just came across these great lights at IKEA.
    They're LED lamps, with an extra-long gooseneck and they're only $10.
    They should be easily adaptable to any machine.
    Check out:
    IKEA | Lighting | Table lamps | JANSJÖ | Work lamp
    Ron_P's Avatar
    Ron_P is offline Aluminum
    Sep 2009
    Cincinnati, Ohio USA
    78
    Excellent idea, thanks...and with an Ikea nearby...I'll be taking two.
    Ron
    Ron_P's Avatar
    Sep 2009
    78
    My wife picked up two, glad she did, these things put out nice bright light, and don't get hot.
    $10/each but she said they were on sale and normally $20.
    I'll fiddle with permanent mounting or maybe grab a few big ring magnets. Thanks for the tip.
    Pali is offline Aluminum
    Feb 2007
    India
    141
    Excellent Idea, make sure that it is water proof, if used for metal cutting operation, especially Grinding.
    Georgineer is online now Cast Iron
    Dec 2008
    Portsmouth, England
    395
    I have been using these for some time, and they are excellent. We use them indoors too. They are also available with a clamp fitting (though the gooseneck is a bit short on those) and in silver as well as black. Incidentally, the low voltage plug and socket on the 'wall wart' supplied with the lamps is a standard 2-pin DIN plug and socket, commonly used for connecting the speakers in stereo systems. (e.g. Farnell Electronic Components part number 150850)
    George
