Marcuschrist
- Jul 11, 2017
Question for any babbitt scrapers here, I was contacted about this white metal bearing in a local desalination plant. The scraping has worn down to the point where unless the use a porta-power to lift the shaft oil can't pass through. They sent me the images below but today I brought a small surface plate, V block and tenths indicator and from the original scraping to the most worn area there looks to be able 0.0013" of wear. Management apparently either can't or won't get new caps and as far as I can tell everyone else in the area they've contacted has refused to touch this job. I was planning on adhering a 1 thou shim to the bottom of the cap, pulling the dowels and matching the tops of the caps to rest of the housing before scraping the babbitt. Does that make sense or is this a horrible plan?
