mfisher
Hot Rolled
- Oct 24, 2006
- Annapolis, Maryland
I have one of the fairly rare, and none too sophisticated Jackson vertical milling machines. Think 2/3 size Bridgeport, with 3hp and a B&S10 taper.
To the point - trying to tighten up the machine some, the y-axis lead screw has a single 6202 bearing at the crank end to take the axial load in both directions. Best I can figure, is that about 0.010 of y-axis backlash is due to this bearing (measuring end play of the leadscrew). Outer race is tight to the frame, inner race is tight to the leadscrew.
Bearing data - SKF HC LO2 I 70747 HC
etched on the edge of the inner race is 6202
both sides open
35mm OD, 11mm thick, 15mm ID (measured with a scale)
Oil hole to feed the bearing occasionally
Bearing runs smooth, but obvious side to side movement of the inner race relative to the outer race.
So this one bearing takes the axial load in both directions as cranking the y-axis in and out, as well as a little radial load. Is this the best bearing for the job, or there another one the same size that is better for axial loads? No other simple way to get another bearing configuration in the space.
Any help appreciated.
both sides open
