Trying to access the knee elevating bronze nut. looks like you could access the top nut of screw shaft thru top under dust shields but dust shields don't slide back. Any help please. My knee is stiff going up and down. Lube it and it got better but still stiff. Would like to remove and inspect.
May or may not apply to a B&S. Did this with my Quartet mill.
- Place blocking and jacks to raise the knee to take the load of the nut, but NOT to stress it upward.
- remove three screws in top flange of bronze nut.
- NOW jack the knee up far enough the screw clears "daylight" by nut height Plus.
- block for safety in case the jacks leak or fail.
- run the nut down the screw, remove, clean-up threads, lube it.
- clean and lube screw as well while it is exposed, full-length.
Reverse the above to re-install. NO NEED (on the Quartet) to do anything at the top end of the screw.
Nut should be run FULLY onto the screw before you put weight back onto it.
Mine had a half-turn of damaged thread, top entry. Dug it out, re-shaped the entry edge, it proved good enough to not have to make a new one.
Hoping you are as fortunate!
