Lurk
Cast Iron
- Feb 10, 2014
- Peak District UK
Newbie looking for a few pointers on getting the best out of a new to me purchase of a 24" cast Iron SE. More info' in the video link.
I have never owned or used a Camel Back SE and having read a good volume of the posts through this forum I remain a little confused as to what is 'best / 'most appropriate' for my SE.
Q1: It is fitted with three steel dome headed 'rivits' on two of the three flats over the Camel Back - such that it sits on these heads when inverted. My understanding is that these are the 'resting points' for storage ? In which case am I to assume that the SE should be stored inverted when not in use and not sat on its working face in its felt lined wooden cover ?
Q2: There are no 'heat insulated' handles - so whats the correct way to handle it to print the scraping surfaces ? Admittedly Im holding it for perhaps half a minute so would doubt it would make any significant difference to the printing with heat pick up from my hands ?
Q3: The working surface scraped finish is very fine (far beyond my skill level) and the depths of the scrapes is very limited - I will try and get a measurement later this week - my guess 0.0001" based on my own work being around 0.0003 to 4". As such getting anything like a decent print is taking my a lot of practice in getting a thin film of ink over the surface - is this typical for a SE scrape ?
Looking forward to your advice.
Mat
YouTube vid - Elliot 14 S Update 1 3 - YouTube
Mat
