Richard King
- Jul 12, 2005
- Cottage Grove, MN 55016
I was writing an answer to one of the other threads and thought we needed a new thread so more folks can read this info. The other thread asked if they could use a wood working machine table as a master plate. Here is what I wrote.
"As one of the guys said...for practice scraping you can use it, but trying to use it as a master NO WAY! A waste of time as there are no supports under it and it will bend and sag to what ever it is used on."
Reminds me of a story I have told on here a few times before. 35 years ago (or so) at Midwestern Machinery Company in Minneapolis they hired a fellow named Bill Tracy who was a top engineer and service tech who worked for Fellows Machine for several years. He came to Midwestern originally to help their men to scrape and calibrate Fellows gear testers. They eventually hired him as an employee. He was a chain smoker and developed a bad cough and died of lung cancer. He was a pain in the butt type of guy but really knew his stuff. I contracted scraping for them back then in the rebuild floor, but never worked with him as he trained a couple of their men to scrape the lead checkers and testers.
Well after he died those 2 guys he trained quit, one started up his own company and the other went to work for Honeywell. So Midwestern hired another guy who had worked for Fellows after they closed the doors. Midwestern had ran want ad's in Springfield VT the birthplace of Fellow. This guy told them he worked with Bill Tracy so they hired him as Bills replacement. They asked me to work with this guy to rebuild the lead checkers.
Well to make the story short and getting back to the plates...He had them make up a wood pattern and cast a "dummy" that is a special straight-edge that has both flat & V cast into the "dummy" so you blue and scrape both ways at the same time. The dummy is calibrated in the lab before the job and no need to check the machine ways with a tester like a King-Way and straight edge.
It was about 3" thick X 30" long and 12" wide and was cast with shallow ribbing in the bottom and had 3 point legs at the far extreme corners. 2 on one end and one in the middle of the other end.
I told that guy and Midwestern management that I felt the plate was weak and would bend. This guy, I forgot his name, but we could call him "That Guy". That Guy insisted I was wrong and seeing he worked for Fellows they had me scrape it to 40 PPI and .00005" flatness and parallel when it was setting upright on it's 3 points. It looked and was super in that position. I used a 36" Camelback straight-ege and a King-Way to test it. He also had me use a dowel pin in the V and a gage block on he flats measuring off a granite table to make it parallel to the 3 points in both long and width directions. This was something I also questioned, but did it as I was being paid by the hour and That Guy was the leader of the Fellows Dept. at Midwestern. He could not scrape, That Guy told everyone he was in the Test lab at Fellows and never scraped.
We started to scrape the ways of a 24 M lead tester using the Dummy. I used it as he watched me scrape the ways. It definitely was fast using it to scrape the Flat and V ways all at the same time. After we were done scraping the lead testers ways to 40 PPI we started to match fit the Tail stock of the tester to the base ways. But when we indicated the quill of the Tail-stock with my Best Test .0001" indicator it would change .002" when we reversed directions when we pushed it in and out when we were trying to make the quill parallel and pointing a little up in front to the base ways (rocking chair). He would scratch his head and said my indicator was bad.
He had them buy a brand new Inter-Rapid and set it up and again we got the same reading. LOL.. He was beside himself...The management came back and finally looked and asked me what I thought was going on. I told them the Dummy plate was bending and the Fellows Base was high in the middle. I then took the same 36" camelback and set on the Fellows Base and hinged it and it was super high in the middle. The dummy would follow the contour of the base and we could not "hinge" the Dummy we never knew it was getting high in the middle (rocking chair). They looked at That Guy and fired him on the spot. Poor Ba__tard had moved out from Springfield VT but he got what he deserved as after that Midwestern did some investigating and he had lied about what he did for Fellows, he had worked in the shipping and receiving dept. and not the calibration lab. They figured he had seen the scraper hands using the dummy and tried to design it from memory, not understanding the ribs or spine of the Dummy had to be designed deep and thin to support the plate when flipped over. That Dummy ended up in the dumpster and I went back to the old way or 36" camel back and King-Way.
So the moral of the story is thin plates not designed to be surface plates when flipped over that don't have high webbing and lots of it will bend. The wood working cast iron table designed to slide wood over it will bend and will not work as a master. Next time you see a old fashion cast iron surface plate look inside the bottom and if it has a lot of webbing, it can be flipped over, but if it does not have webbing and 3 points it was designed as a bench plate to sand on and not be used as a master plate. Rich
PS: Good CI plates are heavy as heck too...
