Clausing 5914 - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: Clausing 5914
  1. #41
    Oct 2008
    Central PA
    528
    28
    This web site is good for most things, but when it comes to Clausing lathes, there's a guy over in the Yahoo Clausing group who's been rebuilding these for years and really knows the variations and how to deal with them.
  2. #42
    Jan 2018
    Georgia
    24
    I was not able to find the clausing lathe group until just now. I had to go to yahoo groups and do a search there. I joined and posted my questions there.
  3. #43
    Oct 2008
    Central PA
    528
    28
    I see Webb has already responded. He's the main Clausing resource for the group and a real angel to those with problems. Follow his advice and get the manual specific to your lathe. They changed the design of certain parts over time, and you have to go by the serial number of the lathe. If you need a new bronze bushing, machining that to size will be a challenge unless you have a second lathe to do the job. Someone used a large drill hooked to an expanding plug in the spindle of his lathe to drive his lathe while he machined the pulleys for the lathe.
  4. #44
    Jan 2018
    Georgia
    24
    Quote Originally Posted by RLamparter View Post
    Yeah I have only seen one other Clausing with the same VS drive as mine. I just wonder why it was changed over, Was it possibly poor in design or did they make changes that were related to cost or what? The bushing itself looks just fine, the pulley half moves back and forth on the shaft nice with no real play that would cause any concern. The part I need is the key that keeps that pulley half from spinning on the shaft. I never found any part of the key which clearly had been sheered off at some point.
  5. #45
    Jan 2018
    Georgia
    24
    I just called Clausing and that key is no longer made so they are sending me the prints for it.
  6. Likes Derek Smalls liked this post
  7. #46
    Oct 2008
    Central PA
    528
    28
    I think Web makes that key - if it's the same as the ones that have the green epoxy coating. That was a common item to get bashed as the parts wore.
  8. #47
    Jan 2018
    Georgia
    24
    It looks like this pulley key is used on many of the Clausing lathes so maybe I can find one although making one will not be hard other than the case hardening specs that the part has.
  9. #48
    Jan 2018
    Georgia
    24
    Do you know what really sucks, I found a price list for Clausing parts from 2005 and this key is $1.23.
  10. Likes JohnEvans liked this post
  11. #49
    Jan 2018
    Georgia
    24
    I may be asking for another scolding but I figured I would inquire about a possible modification. I have a ZF45 milling machine that I had purchased a 2hp Marathon Black max (vector rated) motor and a Danfoss VFD with plans swap onto the mill at some point. The motor is actually a bit heavy for the mill and I am not sure when I will get around to doing that swap anyhow. I was thinking about removing the Clausing VS pulleys and just using this Marathon and the VFD to control the speed. This motor is designed for 100% torque output down to 0 RPM so I would imagine it would be up to the task even when turning slow. I do like the clutch/brake unit on the Clausing so I would just simply remove the VS pulleys and standard V belt pulleys from the motor to the clutch/brake jack shaft. Any foreseen issues with this conversion? Any cons or possibly pros other than possibly a more reliable VS system?
  12. #50
    Jan 2014
    Coventry RI
    938
    973
    719
    Quote Originally Posted by Gmikehall View Post
    You may very well get another scolding but it won't be from me this time. I simply don't know enough about the details of what you propose to know if it's a great idea or if it sucks!
    If I was you and seriously considering doing that, I'd start a new thread in the "Transformers, Phase Converters and VFD" section, and lay out my plan. Lots of guys there that are pretty expert on that stuff and could add some good insight.
    My concern with that stuff is always low end torque. Even though the motor makes the same torque at low RPM, it's very little HP when slowed way down. Better to reduce speed by mechanical means and boost torque while maintaining HP. Maybe add a high/low pulley from the motor to the jack shaft???
    Really sucks when you go to push a big drill and the machine keeps stalling!
