Jon G Houston
- Jul 22, 2016
I'm new to the site. Just begun the restoration of a model 8301, 15-50 Colchester lathe built in 1974. The tail stock quill will not fully retract and trying to disassemble the quill lock. Trying to release the quill lock key, no luck so far so I can't get the lock shaft out of the TS housing. Hopefully the parts diagram and photo are properly attached here. The lock shaft rotation is so stiff I have to use a dead blow to move it! I have the lock handle at ~45 degrees from vertical to release the key. Tapping hard on the opposite side from the handle. No real movement. Putting a drift in the quill slot and tapping suggests the key is solidly in place.
Thoughts? Thanks in advance
Jon
Jon
