matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
I thought I'd share an "aftermarket" handle for hand scraping. The Sandvik and Anderson come with sort of glorified file handles, they are nice in their own way, but will dig a hole in your abdomen.
At Rich's suggestion I used the plastic top cap of an aerosol spray can as a temporary fix to spread out the pressure when hand scraping. The idea is not new as I've seen other versions in use. However I had my own idea for a handle cooking.
I commissioned my Dad who is skilled in wood turning, I sketched up a design on a napkin over lunch and he glued up some 2x4 pine stock for development purposes and made the drawing into reality. I have been testing it and its a nice improvement. I think the only improvement would be a larger center hole to more deeply seat the taper but that's a minor detail.
Thought I'd post for you guys "getting ready to scrape" and acquiring the tools, just buying a shiny brand new scraper doesn't quite cover all the bases. it could also be made of delrin or some other plastic-type material turned on a metal lathe.
