bellaireroad
- Oct 4, 2015
Model number 28 -365. It has variable speed which works. There is also a shift lever to shift from high to low. My understanding is that you need to shift with the machine turned off, however when that is done it will not go into gear. The only way it goes into gear is to shift when the machine is running, and it makes a clunking sound when that happens. Is this a fatal flaw.?
