I need some help figuring out what to get or where to send a gear to have it measured so i can find a replacement or have it fixed. I have already contacted the manufacturer and they wanted an arm and leg for a gear, over $2000 for both witch seems out of line. The smaller gear is still in good shape still so i would like to just have the other one fixed if that is a possibility. That way thing still line up. I know nothing about gears so im hoping to get some help from the guys around here. I can bore the hole and drill the taper pin but have no clue about gears other than that. Here is what i can tell you about the gear.
larger gear (need fixed/replaced)
33 tooth
1" center hole
2.030 tall
small gear
29 tooth
1" center hole
1.413 tall
33 tooth
1" center hole
2.030 tall
small gear
29 tooth
1" center hole
1.413 tall
