Hey everyone. This is my first post here. I was given a lathe today by a co-worker that has been sitting in his basement since he bought his house years ago. It is a South Bend 9" bench model. As near as I can tell from researching the serial number, it is from the early to mid 1940's. It's power cords will need to be replaced, and it needs a thorough cleaning to remove all the oil and dust gunk, but as far as I can tell, there are no catastrophic issues with it. I just have a few questions about a few things to get it back into shape.
1. Lathe stand. Everything I have read so far suggests that a lathe stand needs to be heavy to dampen any vibration, but would a ruggedly build stand of wood be sufficient? I have no welding skills, but know my way around woodworking tools. I have thought about a bench made from 4x4 timbers with a shelf underneath filled with concrete to give it the needed weight.
2. Lubrication. The parts on the headstock and motor seem to turn with only a little resistance, so I am assuming that it still has at least traces of oil/lubricants left in the bearings. What type of oil/lubricants should I be using? I am assuming any lightweight lubricating oil will be find for the bed and screw drives, but I am unsure of what to use in the bearings and other parts that may require more specific viscosities or formulations.
3. Unknown part function. On the back side of the lathe behind the pulleys for the flat drive belt, there is another shaft with gears on each end that moves to engage gears on the head stock, but while everything spins easily by hand while disengaged, when the mystery shaft is engaged, everything locks up and cannot be moved. It can be seen in one of the pictures below.
4. Threading function. As far as I can tell, there is no thread cutting function on this lathe. Anyone familiar with this model of lathe know if this is common for them? Every other reference picture I can find of this model has the threading selectors shown on the lower left, right below the headstock.
