Hello good morning everyone,
I like to request the benefit of the wisdom and knowledge of the forum. So I'll lay out the story behind the problem.
I purchased this nice 15 inch Leblond servo shift from a school auction last year and have just recently started using it after building a RPC for it. Since it has a 7.5 hp motor it took me a while to find another motor to convert.
At first I used a VFD to run the lathe at low speeds and was successful in testing functionality but now that I have run it at full speed I noticed a knocking noice when high speeds are engage 640 -1200. After examination and looking all over the internet everything was fine but then I observed when I turned the spindle with a power drill, that it was coming from the high speed spindle. Closer examination revealed that the timing pulley has a little play and each revolution it clicks. It's not a major play but with the pressure from the timing belt it clicks noticeably at high speeds
I looked for set screw to tighten but found none, so I though I could drill and tap to add one but also figured it's a design feature and I should just let it be. After all I don't think it will wear out the shaft and the pulley in my lifetime with it, or then again it might?
What do you think? Has this been seen On Other lathes?
Thank you in advance
