d1camero
- Sep 16, 2005
- BC, Canada
I have two 16" feed rollers (from a 30 year old planer - a beefier version of the Makita 2040). They are probably urethane. Tested to be about 70 durometer. Both are worn towards the center. One to about 20 thou, and the other to about 35 thou measured in radius.
I realize that I can get them recovered (e.g. western roller), but dollars are tight, so I wwas wondering if I could chuck them up in the metal lathe and resurface them? I have seen a couple of article about using a tool post grinder (which I do not have), and use HSS with a round bull nose. I have some HSS blanks, and a fair bit of carbide tooling.
I suppose another question is if I take of 80 thou from the diameter will that have a negative performance on the machine? The rollers are about 2.5" in diameter.
thanks!
thanks!
