I have an old Summit (Japanese) 11X32 lathe. It works fine, but I hate the tool post. It's actually built into the compound slide itself. Instead of a T-slot, there's a raised boss that the 4 sided tool post pivots on. I'd really much rather use an Aloris type dovetail tool post.
I could just machine the boss off of it, and machine a T-slot, but the slide is very thin, and I feel it would weaken it too much. I also considered building it up with a couple inserts bolted to the top to create a T-slot without cutting down into the slide. I'd let the inserts down into the slide slightly to key them in place. I'm not sure how well that would work in terms of rigidity, though.
The other option would be to make a new slide out of cast iron, making it taller so that I could cut a T-slot in it and still have sufficient material. There is enough spindle height for this to work with an A-sized tool post.
Any thoughts? Is there any reason whatsoever to preserve the original slide, or should I just hack it up however I see fit? If that fails, I could just make the new slide. You never know when someone is looking for a part, though. I'd hate to ruin in and then see that someone is looking for that very slide to fix up their Summit.
