toolnuts
Cast Iron
- Sep 27, 2009
- washington
Hello All, and NateA2,
In NateA2's photos of his Federal electronic level, it didn't look
like a LVDT implementation to me.
It is not very clear what is going on in that level.
The moving part, I think, is a copper or brass loop, and it is moving
along a brass bar. The photos are not defined enough to tell.
If the moving part is copper or brass, it's not an LVDT.
If the bar is brass then I'm not sure what's going on.
An LVDT has to have a moving part that magnetically couples
the sensing coils to the primary coil. You can move the coupling
rod or the coils. If these parts are brass, then no magnetic coupling
occurs.
If the bar, the loop travels along, is iron/steel, then the loop
can act as a magnetic shading device.
The coils appear to be mounted above the iron loop/core on that flat
section the wires are connected to.
I would love to know all the real details of this device.
Is the manual, for this device, on-line somewhere, and does it explain
the device in more detail?
Regards to all,
Paul
occurs.
Regards to all,
Paul
