MAG LAB
- Sep 5, 2014
- Pomona, CA USA
Howdy,
I've got an old American Millrite manual mill that i'm trying to recondition to offload so i can drop in a newer slightly larger mill. My issue is that the nod on the head has developed a wobble from the poor repairs of a previous owner on the two/four taper pins that fix the shaft on which the head pivots to nod. I believe he ran into the same issue i'm having now which is the difficulty in sourcing a long enough taper pin reamer to match the taper the full length of the bore. From the attached pictures you can see the pivot point is about 5" of which the shaft to be fixed to the mast casting is 3". I can find #4, #5, #6, #7 taper reamers, but i cannot for the life of me find any thing like a combination reamer (it covers the sizes from #4-#6)to cut the whole taper at once since i am doing this manually and do not trust myself to independently match 3 tapers to each other. More frustratingly, the #4 i got (thinking i could match the tapers) drops so far into the hole, i cant get any hold on it for which to apply the necessary torque or pressure for reaming/cutting.
If anyone can help me source a long taper pin reamer that at least will cover the range of taper from 0.319" to 0.252" such that i've got about 0.25" of pin extending out either side of the main shaft. Or help with some other solution to fix this shaft.
