radiocontrolhead
- Jan 8, 2018
Hey all.
Quick question. Am I out of my mind for trying to bring the 4 raised blocks on the base down to the same level by means of filing? I do not have access to a mill or a grinder at this time (will grind the other 3 blocks using a powered grinder).
My real questions, without a mill to bring all 4 blocks to within a scraping tolerance (say a thou) am I in over my head to rough scrape to where i need to be or will i be chasing my tail.
I'm really new to this whole thing and I wanted to get started on the project and may have jumped the gun a bit too early.
The idea was to great a much more uniform and even bearing surface instead of just the 4 tiny blocks that the column sits on.
Thank you all for your help.
Again, I'm a newbie and appreciate your patience and input!
