collector
Hot Rolled
- Nov 1, 2007
- Parksville BC Canada
Hi guys
I am ready to set up the outboard supports on the PAMA boring mill. And looking for any suggestions or proper methods to set the two rails upon ether side. There around ten feet long. So I am gonna use some 1x8 fat bar drill and tap for the stud holes for the leveing screws. Put the studs in the flat bar lower the rails on to the studs. Then side the rails under the legs. Anchor the flat bar to the floor. Level the rails to the machine. Now this is were is the level good enough? So I would center the table and carriage bring up the rails to the wheel or rollers in the legs. The wheels rollers are on a eccentric shaft with .040 movement. So do you what the rollers touching or bearing on the rails ? Here is a picture of the machine and in action.
Thanks Collector
Thanks Collector
