Marcuschrist
- Jul 11, 2017
I just drove to Brisbane to pick up my 7elm Biax from Braithwaite electrical and now the assembly that reciprocates moves back and forth freely. when I turn the scraper on it doesn't move but if I apply pressure to the blade holder it does. I paid $700.70 to have it rewound from 110v to 220v but they're also put new bearings according to the bill ($11 each which seemed uncomfortably cheap), could they have have put the wrong bearings in shifting the position of the armature in relation to the mechanism or assembled it incorrectly?
I never tested it before dropping it in as I don't have a transformer but the bladeholder assembly was definitely not like it is now, you couldn't push it back and forth freely like this. I tested it while I was there and when it didn't work the tech came out and told me you had to press it in to make it work which doesn't seem right at all. The only experience I've had with a biax is at Richards class in Denmark so I'm a complete novice and might be missing something obvious so any advice would be appreciated.
