stephen thomas
- Jun 3, 2001
RE: cross slide issues
I don't want to step on any toes or be out of line.
I do think a closed post about cross slide issues on, lets say a worn out old lightweight American classic such as a LeBlond Regal series or an old South Bend, for instance, were never really addressed.
Someone asked how you could survey the cross slide ways.
One quick way for someone with minimal equipment other than a DTI to do a peremptory "survey" would be with a dowel pin. First level the lathe, do the collar test and turning, align the headstock.
Mount a 10ths DTI to a faceplate or chuck such that the probe extends radially out just far enough to miss the lathe ways, wings of the carriage, and anything in between when the spindle is rotated by hand. Remove the topslide. Lock the carriage to the ways*. Use a clean new dowel of sufficient diameter to lay in the dovetail and contact the bottom flat way and about 1/2 to 3/4 up on the dovetail. Put the dowel at the leadscrew side of the ways and swing the DTI to find the highest reading. Move the dowel to the far side and swing the DTI again observing the highest reading. Compare. Obviously do repeat readings and observe all best practice.
Stepping up a notch with equipment, scrape the bottom of the cross-slide flat to a surface plate. Then use that and a dovetail straight edge to scrape the flat part of the cross-slide ways, flat all over*. (Keep them equidistant from the carriage-to-bed ways of the carriage so the cross slide travels neither up- or down- hill). Next use the dovetail SE to scrape the non-gib side of the carriage top (cross slide) ways dovetails straight, and to the offset desired for the lathe to turn concave when infed normally. IOW, continue to use the Dowel and the DTI on the spindle to monitor progress and inform which end of the dovetail to scrape more heavily. End up certain the way is straight, not curved.
Now, mic'ing over dowels to keep the ways parallel, scrape the back/gib side of the ways parallel. Then scrape the cross slide ways to match, keeping them essentially parallel. Then fit and scrape the gib.
It is pretty obvious why people think this would be a worthless enterprise on a low cost poorly designed import, but it might be better to just lay out the work entailed and let them make their own decision. Sometimes if we ignore where the machine came from, many of us can learn something new about the process applied to "any" machine. To some people who may eventually become "professionals" following such a process on a "junk" machine may be a good learning experience and better than taking on something bigger and "better" anyway. People learn best from their own mistakes despite all well meaning advice.
I scraped a whole bunch of wood-whacking equipment when starting out, including a tenoner, and a run of shaper sleds/fixtures I used to sell (due to not having a surface grinder at the time) Later/20 years ago, I rescraped a Taiwan mill drill bought new and worn out by me even longer ago. Not supposed to talk about it, but it is still a good machine and gets regular use. (Got plenty of good old American iron, too, of course including a regular SB turret mill)
*Obviously it should also have been determined that the carriage was a good, non rocking, full contact, scrape fit with the ways, before locking the carriage "gently" to begin surveying and scraping the cross-slide ways. Since it is owner's lathe, make your own choice about whether to spot and scrape in the clamped or relaxed condition. On small lathes facing is done with carriage locked. If the carriage fits well made ways, either choice works fine, and I have done both on my own lathes.
A reminder: Once you scrape in the cross slide ways, you are locked in to that exact geometry for lathe bed level and spindle alignment "forever", so be sure they are correct before proceeding.
That said, i don't doubt that even "close" could improve the accuracy of a lot of small lathes, imports or worn out Euro/American.
But it is not a trivial process, so as mentioned in previous posts, select your re-build candidate wisely.
smt
smt
