Heres a quick run through of what I did on the old Schou grinder. Will try and let the pics do most of the talking
Before the job, I made up some vee blocks that attach to a mercer indicator stand for the levels to ride, used them to keep an eye on the top vee angle to make sure I didnt wander.
Found out that the ways were in fact soft, not hard as previously thought.
First job was to survey the machine. After removing the wear ridges, I used a base level to be sure the machine wasnt moving with me tramping all over it, as you do, or as you dont
Original machinings were present at all corners of all the main surfaces. Result!
