Jorje_villafan
- Oct 18, 2017
- Salem, Oregon
Well I'm super new to the metal working world and recently acquired an old Power Kraft Lathe (Logan, as I'm sure most of you may know). As I was taking it apart to clean it, the bearing cover screws, while they seemed snug in their homes upon first loosening, soon spun freely in place with the exception one which backed out all the way, but after further investigation, saw that all 3 screw holes were stripped and I could (after using a strong magnet top get them out) just push them all the way in without spinning. That seems to be (in my limited knowledge) the only issue that needs serious attention with this lathe.. Pretty sure re-tapping is not and option as the heads cannot be larger, as they fit snugly into a recess.
So my question is, is there a way that you machinist fellas and fellettes handle this situation? Epoxy maybe? I don't wanna try anything without getting some seasoned advice!
Thanks!
Sent from my Pixel using Tapatalk
Thanks!
