Hi,
I'm trying to reinstall the piece gap in a Colchester Triumph 2000. According to the measures I took the size of these taper pins (2) should be #10, but now I'm unsure about it. The pin enters but they got stucked at the middle , may be is because the hole diameter was dirty or deformed by the lack of care in the past.
I order to avoid any problem, I would like to know if some of your know the right size of these taper pins, in the user manual this informations doesn't appear.
Thanks a lot
Thanks a lot
