This is a very nice preowned HH Roberts Topwell TW-96 Bed Mill with 2017 Centroid Upgrade, Head is 5-HP Inverter drive, with 40-Taper Spindle, Made in Canada by H.H. Roberts Machinery Manufacturing. Handwheels on X and Y Axes for manual operations. Machine was used to cut ABS plastic tubing in a rotary table application. The machine is immaculately clean and ready for your application. It was set up for a rotary index application, so the wiring of the miscellaneous m function is there as well as an air solenoid valve for an air brake on the rotary.
SPECIFICATIONS:
Ballscrews on X,Y, and Z axes.
Counterweight on head.
1000 Lb. Table Load
Quill Dia. 4.175"
Spindle Speeds-variable: 70-3800
Table size: 10 x 50"
X-Axis travel: 32"
Y-Axis Travel: 20"
Z-Axis Travel of Head on Column: 21"
Quill travel: 5"
Spindle Nose to table: 2-23"
Spindle Center to Column: 18.97"
Width of Saddle: 22"
Handles for Manual Feed - YES
Machine weight: 4,600 Lbs.
Rapid traverse Rates: 240-480
M-Functions for programmable coolant
M-Functions for Spindle On/Off
Fully Programmable Spindle Speeds
Power Drawbar for Tool Changes
208 to 230 VAC 3-phase and 120 VAC single phase.
Automatic Lubrication
Flood Coolant System
Side Splash Guards (72" high)
Large Chip Pan.
Am asking $15,000 shipped.
Contact email:[email protected]
SPECIFICATIONS:
1000 Lb. Table Load
Quill Dia. 4.175"
X-Axis travel: 32"
Y-Axis Travel: 20"
Quill travel: 5"
Large Chip Pan.
