aninventor
- Dec 31, 2009
- Ohio - USA
K.O.Lee tool and cutter grinder with a 3 X 21 inch universal swivel table with center T slot and with the optional tilting rear manual tool grinding table. It comes with a cutter tooth rest, but no other tooling or grinding wheels. The two grinding wheels shown installed are from my other grinder and are not included. The rear table takes wheels up to 6 inch diameter. The front table can take larger diameter wheels.
This is a model A600 grinder, a small bench top sized machine seldom found with the optional rear manual grinding table. It occupies an area of about 30 inches wide and deep and high, and it is the ideal size for a smaller shop space. It can also be used to grind small chip breaker grooves in carbide inserts. It has a 220 Volt 3 phase motor.
It is located in the Dallas Ft.Worth Texas area.
$750
Lee
thermoman at verizon dot net
