MotoX
Cast Iron
- Nov 14, 2011
- Enid, Oklahoma
Model: 1R S/N 862-29 New:1977
Nominal Swing over table: 10"
Maximum swing :10-7/8
Between centers: 20"
Max. wheel width : 3"
Wheel Dia.: 16"
Work dia. reduction per revolution of handwheel: .1"
Fine feed Graduations: .001"
Wheelhead Motor: 3 HP
Workhead swivels
-Toward wheelhead: 90 degrees
-Away from wheelhead: 30 degrees
Workhead spindle nose: A2-5"
Workhead motor:1/4 HP with variable spindle speeds
Automatic lubrication
Self contained coolant system
Approximate weight: 4,150 LBS
Approximate dimensions: 8'L x 4'W x 6'6"H
We bought this unit as a backup to our production grinder in 2008. Since then it has seen about 10 hrs of use. It is no longer needed, but the floorspace is, so it has to go.
The unit is under power in Enid,OK. Come in and inspect it at 412 N. Independence 8-5 Mon-Fri.
Unit was originally wired for 440 3 phase, but has been converted to 240 3 phase.
Price is $7000.00, but negotiable.
Wheel Dia.: 16"
Workhead swivels
